Error: NgdBuild : 630 module is missing an area group property
hi
i m trying modular flow in that whem i m doing implementation of individual module i m getting
error saying missing area group property.
can anybody help in this?
Re: Error: NgdBuild : 630 module is missing an area group property
Modular design is not used common any more,
because it need area constraint and other synthesis constraints
it is not easy to use
partition is used more common
Please see xapp918
Hi Jalpa_29,
As Yangliiris suggested , XAPP 918 (Incremental Design Reuse with Partitions) may be helpful for you because modular design is pretty old one ..
It ( XAPP918) is about Partitions which is the new solution instead of the old Modular Design flow.
XAPP918: http://www.xilinx.com/support/documentation/application_notes/xapp918.pdf
--Venkat
