Visitor gaurav_pc
Error while running implementation through unix command line
I am new to Xilinx and bash scripting. I am using Xilinx 13.4. I am trying to run implementation(ngdbuild, map, par etc) to create the bit file through a bash script, but I am getting an error. Following is the snippet of my error :-
Running synthesis...
bash -c "cd synthesis; ./synthesis.sh"
xst -ifn system_xst.scr -intstyle silent
Running XST synthesis ...
PMSPEC -- Overriding Xilinx file
</tools/Xilinx/13.4/ISE_DS/EDK/virtex5/data/virtex5.acd> with local file
</tools/Xilinx/13.4/ISE_DS/ISE/virtex5/data/virtex5.acd>
XST completed
error status of previous command:0
=> Starting xst: Xst log file is: no_file.syr
Using xst file - no_file.xst
ERROR:Xst:427 - Entry File no_file.xst not found
 Can I get some help on this?
Gaurav.
Re: Error while running implementation through unix command line
Does "no_file.xst" exist and in the directory where XST is running?
Visitor gaurav_pc
The file no_file.xst and no_file.syr does not exist in the directory. When I run the process through gui these files get generated but I don't know which command generates those files. Yes, I tried to search the web for the error but I have not found a solution.
Since this is an XST issue, you might want to take this to the Synthesis forum.
Please post the contents of synthesis.sh and system_xst.scr
Visitor gaurav_pc
Contents of synthesis.sh
#!/bin/bash
rm -rf xst
echo "xst -ifn "system_xst.scr" -intstyle silent"
echo "Running XST synthesis ..."
if [ $? -ne 0 ]; then
  exit 1
fi
echo "XST completed"
rm -rf xst
Contents of system_xst.scr
run
-opt_mode speed
-netlist_hierarchy as_optimized
-opt_level 1
-p xc5vfx200tff1738-1
-top system
-ifmt MIXED
-ifn system_xst.prj
-ofn ../implementation/system.ngc
-hierarchy_separator /
-iobuf NO
-max_fanout 10000
-sd {../implementation}
-vlgincdir {"/path/" "/tools/Xilinx/13.4/ISE_DS/EDK/hw/XilinxBFMinterfa
ce/pcores/" "/tools/Xilinx/13.4/ISE_DS/EDK/hw/XilinxProcessorIPLib/pcores/" "/tools/Xilinx/13.4/ISE_DS/EDK/hw/XilinxProcessorIPLib/pcores/block_plus_v1_13_a/hdl/verilog/" "/tools/Xilinx/13.4/ISE_DS/EDK/hw/XilinxProcessorIPLib/pcores/plbv46_pcie_v4_07_a/hdl/verilog/" }
and the contents of system_xst.prj
Visitor gaurav_pc
Contents of system_xst.prj
verilog work ../hdl/systm.v
There is nothing wrong with the material that you posted that I can see, but after looking at your first post it looks like you may have another script calling the synthesis.sh script is that right?  If so then the error is most likely in there.
Visitor gaurav_pc
I have just one command calling synthesis.sh in the script also after XST it does not generate other files(.ngc files) which are required for ngdbuild. When I run through the gui I am not having this problem though.
