Errors during place design
Getting the following error during the place design
ERROR: [DRC 23-20] Rule violation (REQP-123) connects_CLKINSEL_VCC_connects_CLKIN1_ACTIVE - ............/..................../........../........../........./ila_mmcm/inst/mmcme3_adv_inst: The MMCME4_ADV with CLKINSEL tied high requires the CLKIN1 pin to be active.
I have connected the CLKIN1 to a valid source from a zynq pll
I Wanted to provide a 2x clock to the ILA so with the given clock provided the input to a mmcm and conneccted mmcm output to ILA
Mentor
Mentor
It sounds like there is a connection problem of some sort.   Load the routed design into Vivado,  find your MMCM in the netlist, and hit F4 to generate a schematic of the MMCM..   Then trace the connection on CLKIN1 backwards (by double clicking on the CLKIN1 pin) to see where the driver is located.
Mentor
Mentor
