Visitor gaurav_pc
Errors while running Translate
When running Translate in the ISE tools, I receive several of the following errors:
ERROR:NgdBuild:467 - output pad net 'fpga_0_ddr2_clk_0_OBUF' has an illegal buffer
ERROR:NgdBuild:467 - output pad net 'fpga_0_ddr2_clk_1_OBUF' has an illegal buffer...
ERROR:NgdBuild:947 - bidirect pad net 'fpga_0_ddr2_dq_0_OBUF' is driving non-input buffer(s): pin I on block fpga_0_ddr2_dq_0_OBUF with type OBUF
ERROR:NgdBuild:947 - bidirect pad net 'fpga_0_ddr2_dq_10_OBUF' is driving non-input buffer(s): pin I on block fpga_0_ddr2_dq_10_OBUF with type OBUF...
Why do I see these errors, and how can they be resolved?
I have tried http://www.xilinx.com/support/answers/32847.htm but it does not work.
Can I get some help on this?
Gaurav
Visitor gaurav_pc
Re: Errors while running Translate
I am trying to run Implementation to generate the bit file and goinr through (ngdbuild, map, par, bitgen etc) I also tried disabling "Add I/O Buffers" according to http://www.xilinx.com/support/answers/34771.htm .
But then I get errors during MAP for :   "DDR2_SDRAM/DDR2_SDRAM/u_ddr2_top/u_mem_if_top/u_p
hy_top/u_phy_io/gen_dqs[0].u_iob_dqs/gen_dqs_iob_ddr2.u_iobuf_dqs" (output
   signal=DDR2_SDRAM/DDR2_SDRAM/u_ddr2_top/u_mem_if_top/u_phy_top/u_phy_io/gen_d
   qs[0].u_iob_dqs/dqs_ibuf) does not have IOSTANDARD specified. Map is unable
   to generate a default IOSTANDARD for IOBUFDS, one has to be explicitly
   provided.
How can I solve this problem?
Gaurav
