Orzica
Is better for performance to infer or to instantiate a FIFO? Which way is better?
Thanks!
syedz
@Orzica
I don't think FIFO can be inferred in Vivado. Please check this below post:
https://forums.xilinx.com/t5/Xilinx-IP-Catalog/Can-you-infer-a-FIFO/td-p/960995
--Syed
syedz
@Orzica
--Syed
joancab
Advisor
Advisor
I most of the times explicitly instantiate to not confuse future users or myself in the future. In terms of speed (if that's what you mean by performance), as long as it works I'm happy. It could happen that an inferred Fifo uses less resources, not sure, being quite a basic building block. It may depend on each particular case and on what one understands by 'performance'
joancab
Advisor
Advisor
richardhead
@joancab That is a shift register, not a FIFO.
