Observer jff118
FPGA Editor Manual Routing a LUT
Hello everyone-
I am in the middle of debugging a timing problem I'm having in the FPGA.  I know its has to do with clock domains and that if they code was done correctly I wouldn't need to do this, but its not my code and I am just trying to fix it.  Moving forward.
I have had this problem in the past where I either want to add some signals to a LUT either to be used with Chipscope or part of another equation.  I don't want to rebuild the entire design because it changes the timing and takes to long.  I have been able to succesfully route signals to PINs via FPGA editor.
HOWEVER, when I try and route a signal to a LUT i end up with this problem show.  The net routes fine in the the fabirc, however the LUT port to the LUT itself becomes disconnected and I can't seem to figure out how to connect the net from pin B3 to the actual LUT pin A3.  I have been searching forever on this and can't seem to find an answer.  Is this even still possible???
The Design is a Spartan 6 and I'm using ISE13.4 and 14.3 depending on the day :-(
JoeLUT Route
Observer jff118
Re: FPGA Editor Manual Routing a LUT
Ok so I have a solution now after playing around a little more.
Even though hte equation is already written inside the LUT, when I deleted the net going into the slice the tool deleted the net going into the LUT.
I have to open the equation editor and make a change, it didn't even matter where it was but I had to trick the tool to thing something changed.  I just ended up removing the component to the equation I was using and saving.  Then I added it back in and saved again and it worked.
Moving to Implementation Board
Debraj
Observer jff118
Anybody?????
I think the problem is that you have not defined a LUT equation that uses that input. Once you do that I would expect the connectivity to be displayed. Select the F= button to display the LUT equations and edit them.
Observer jff118
No thats not the case, the equation is already definted.  In this case there was already a pin defined for that input to the LUT.  I deleted it and added a new net to the PORT on the slice.  However the connection inside the slice is not there anymore.  I didn't have to change the equation inside the LUT since it was already definted.
Observer jff118
