Observer marte
How I can understand a route?
I wish force some routes by UCF, but I want understand how interpret all this values:
NET "U1_RP1/out1"
ROUTE="{3;1;5vlx50tff1136;a7488f7c!-1;-69680;-63848;S!0;0;-8!1;-683;-56!"
"2;0;328!3;843;168;L!}";
Somebody know any userguide for that?
Re: How I can understand a route?
The dirt constraints are actually relative constraints rather than absolute and can be used on any net as long as the same number of pins and relative pin locations is maintained. The constraints are not human readable and so it helps to keep the NCD that was used to generate the constrait available as a reference.
Scholar pratham
You mean you want to read DIRT Constraint..if it is then let me tell you there no user guide to interpert DIRT Constraaint.
Kindly note-  Please mark the Answer as "Accept as solution" if information provided is helpful.
-Pratham
Community Manager
Community Manager
DIRT constraints are inferred by the tool. The user can use it as is.
These are absolute locations for the router to understand and lock the routing of the net.
Ideally these numbers shouldnt mean much to user. There is some more information on DIRT and how to apply in the following AR.Hope it helps.
http://www.xilinx.com/support/answers/35556.html
Observer marte
About route priority? The PAR first look about dirt constraints, and only after that start routing the rest of the routes, right?
Best Regards,
M
Scholar pratham
Yes you are right.
Prathamesh
-Pratham
