khaalidi
How can I constraint placement of design inside a specific slice using the LOC constraint without mentioning BEL and LOC for each Cell.
My design takes up 4 LUT so it can be placed in one Slice. I want the placement in specific locations. Since my design is parametric, I want to just instantiate multiple instances of the Module and pass the Slice Location in a parameter as LOC=SLICE_XnYm .  I don't wanna mention which Cell is taking which LUT.
I want to only provide Slice information.
with only using the LOC=SLICE_XnYm  inside the module, It show some some LUTS in Cyan and some in orange. Cyan as Placed and Orange as Fixed. Will it make any issue?
`timescale 1ns / 1ps
(* keep_hierarchy = "yes" *) module RO
#(parameter SLICE = "SLICE_X43Y0")
(* dont_touch = "true" *) input enable,
(* dont_touch = "true" *) output clk
(* LOC = SLICE *)
// Intermediate Connections
(* dont_touch = "true" *) wire w1,w2,w3;
(* dont_touch = "true" *) and #2 (w1, enable, clk);
(* dont_touch = "true" *) not #1 (w2,w1);
(* dont_touch = "true" *) not #1 (w3, w2);
(* dont_touch = "true" *) not #1 (clk, w3);
endmodule
module top(
        output out
wire enable, clk1, clk2;
 RO  #(.SLICE("SLICE_X0Y99")) R0(enable, clk1);
 RO  #(.SLICE("SLICE_X0Y98")) R1(enable, clk2);
endmodule
❝Analogue by birth, Digital by design.❞
khaalidi
Update: If I use SLICEL slices then the placement is OK, but It's status is still  Fixed not Placed.
@khaalidi
Please see the RLOC property that is described in UG903(v2020.1), starting on page 163.
Cheers, Mark
khaalidi
Why is the placement Ok for SLICEL slices but not for SLICEM?
SLICELSLICEL
SLICEMSLICEM
