How can I create this kind of net (connecting to GND) when using ECO
Hi All,
I have a question about using ECO. I'd like to connect the the pin of R to GND, but how can I create this kind of net like figure below.
@araongao2015,
Check this link:
https://forums.xilinx.com/t5/Vivado-TCL-Community/How-to-connect-a-net-to-constant-VCC-or-GND/td-p/443170
--Syed
@araongao2015,
Did the above post address your query? If yes, Can you please close this thread by marking the post as "Accept as Solution"
--Syed
