How can i use inverting clk in SLICE?
In this picture, i want to know to use CLK_B instead  CLK.
You will need to add the inversion to the source.
Historian
Historian
myFlop : process (CLK) is
begin
    if falling_edge(CLK) then
        q <= d;
    end if;
end process myFlop;
Hi ,
You can use the primitives in the FPGA to invert a clock that is much stable .
With regards
Vintu
Historian
Historian
@vjose wrote:
Hi ,
Why would you want to do that when the code snippet I provided does exactly that, without the unnecessary instantiation of primitives?
Use FPGA editor change it, I guess you want do a ECO on a exist nice file.
Just click on the arrow down button, then you can direct click on the invert path triangle to change the path.
Historian
Historian
That's very dangerous. Then the source doesn't match what gets loaded into the FPGA, and the next guy who has to deal with this will wonder what the hell is going on.
