Visitor zzmzc333
How to instantiate a hard macro in Verilog
Hi!
I  am trying to instantiate a hard macro in Verilog code but it gives some errors:
=ERROR:NgdBuild:76 - File "D:\macro\macro/c_OBUF.nmc" cannot be merged into block
ERROR:NgdBuild:604 - logical block 'U0' with type 'c_OBUF' could not be
   resolved. A pin name misspelling can cause this, a missing edif or ngc file,
   case mismatch between the block name and the edif or ngc file name, or the
   misspelling of a type name. Symbol 'c_OBUF' is not supported in target
   'spartan6'.
The name of the hard macro is c_OBUF. I appreciate any advice you have.
Thanks!
Scholar jmcclusk
Re: How to instantiate a hard macro in Verilog
This is just a guess, but I think you should remake the hard macro using all lower case for the names and pins.  There may be some case sensitivity here.
Visitor zzmzc333
I think you are right. I renamed the macro with all lowercase letters. This time it passed the translate. But map gave me some new errors:
ERROR:Place:835 - Given the original pre-placement, no legal placements can be
   found for 1 group(s). The following is the description of these group(s). The
   relative offsets of the components are shown in brackets next to the
   component names.
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Do you have any suggestions? Thank you.
Tags (3)
Scholar jmcclusk
This has something to do with your hard macro design, which is probably involved in IO buffers, given the naming.   Are you placing a large number of macros?  or just one?   and is it in the same place on the die as you used in FPGA editor?
Visitor zzmzc333
I just tried one really simple case. There is just one small hard macro which only occupies one slice. I am not sure where is it placed because the design can not pass the implementation (it stopped at "Map" because of those errors).
Visitor zzmzc333
Thanks for all the helps, my design passed the synthesis and translate but the it stopped at map with these new errors:
   component names.
I could not solve this though I have tried many things. I have also searched some similar posts from xilinx website but the solution accepted is hard to understand for me. Does anyone have some advice? Thank you very much!
Scholar jmcclusk
Let's go back to basics here..   What problem are you trying to solve with a hard macro?
Visitor zzmzc333
I think what I want to do is figuring out the correct way to use a hard macro in my verilog. I have tried many ways but they are all stopped when running "Implement Design" by the errors mentioned above.
