Anonymous
Not applicable
How to lock placement for Vivado design
I have a microblaze design and it works fine for certain verilog code. If I did simeple changes like adding a register for read back, then the simulation totally messed up. I am not quite sure what caused it but it is probably related to the microblaze memory. I believe the clock timing constrains are already in place, there's nothing I can do to fix it!
I am wondering if there's a way to lock the implementation placement so it can be used for the future changes.
Tony
Re: How to lock placement for Vivado design
Please refer to the following AR. The methodology also applies to Vivado.
http://www.xilinx.com/support/answers/40903.html
If it's just about locking a design, you might want to look at the TCL command "lock_design" (see ug835).
I'm using this command to lock my "golden" static design in my partial reconfiguration TCL flow.
Anonymous
Not applicable
Thanks guys! It turns out the problem is caused by Vivado 2014.1. I ungrade to Vivado 2014.2 and the implementation is consistent now!
