kimjaewon
How to prevent the VIVADO from using specific cells in a specific Slice?
Hello.
I'm using Vivado 2018.02 and KCU116 evaluation board (equiped with xcku5p-ffvb676-2-e).
In the XDC file, I designated(fixed) some particular logics in some particular slices such as
set_property LOC SLICE_X63Y60 [get_cells {cell_A}]
set_property BEL CARRY8 [get_cells {cell_A}]
or
set_property LOC SLICE_X63Y60 [get_cells {cell_B}]
set_property BEL AFF X63Y60 [get_cells {cell_B}]
Below figure 1 is the FloorPlanning(Device tab) after implementation.
        figure 1.
In the above figure, orange cells(carry8 and FlipFlops) are cells that I have manually fixed in my XDC code.
Blue cells(LUT) are cells that Vivado have automatically located.
The problem is that in some particular slices, I just want my manually fixed logics located there.
For example, in figure 1, Slice_X79Y42 have only those cells (carry8 and FFs) that I have fixed.
However in Slice_X79Y43, in addition to carry8 and FFs, there is a LUT which I want it to get rid of (which I want the VIVADO to locate it in another slice).
That is, I want the slice to be used exclusively for only the carry8 and FFs that I have fixed (I'm going to use only the carry8 and FFs other than LUTs and MUXs).
In below figure 2 and figure3, I can see that because of the unwanted LUT, the number of cells in SLICE_X79Y43 and SLICE_X79Y42 are different.
        figure 2.
        figure 3.
How can I protect the slice and use if for my own?
Is there a specific XDC code for it?
Do I have to block the other cells (LUTs and MUXs) which I'm not going to use?
Thank you very much.
rshekhaw
Hi @kimjaewon ,
Yes you can apply on specific LUT and MUX. The simplest way would be to click on the particualar LUT or MUX in Device view and Go to BEL Properties-> Properties-> PROHIBIT and click the check box in tcl console you will also get the equivalent command for that:
Raj
drjohnsmith
I only have small screen at moment , so can't search,
What u need to look at I think is the block planning idea , part of partial reconfiguration topics I think
Sorry , no more than a pointer , but it is possible to block out an area as "mine" , in which u can place your own logic and the tools will not invaid.
U might have t use relative placement as opposed to absolute ,
Hope that's some help
barriet
You could try adding a PROHIBIT constraint to the LUT sites in question here.
see https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug903-vivado-using-constraints.pdf
Cheers,
bt
drjohnsmith
Having found a bigger screen,
I was remembering ( badly ) Floor planning and Pblocks
http://arco.esi.uclm.es/public/doc/tutoriales/Xilinx/old_training/PlanAhead/benefits-of-area-constraints.ppt
barriet
kimjaewon
@barriet
Hello.
Thanks for your advice.
As you mentioned, I used the PROHIBIT in the XDC file as below code.
set_property PROHIBIT TRUE [get_sites SLICE_X63Y29]
The result is below figure 1.
        figure 1.
SLICE_X63Y29 was prohibited so VIVADO couldn't locate any cell in that slice.
However, what I want is to prohibit only particular BEL (LUT and MUX) not the entire SLICE like below figure 2.
        figure 2.
Is there a way that I could leave only the CARRY8 and FFs and prohibit the LUTs and MUXs?
How can I modify my XDC code?
I tried something like
set_property PROHIBIT TRUE [get_sites SLICE_X63Y29 -of [get_bels F8MUX]]
but it didn't work.
rshekhaw
Hi @kimjaewon ,
Raj
