Newbie irun2
How to prevent the mapper to remove logics?
My design has some delay cells building up with several BUF primitives. At the end of every instance line I've put (*KEEP = "TRUE" *), and synthesis report shows:
    Set user-defined property "KEEP =  TRUE" for instance <dly_loop[0].buf_gen> in unit <delay>.
This makes me believe the KEEP attribute has take effect...
But in the implementation stage, *mapper* considered the BUFs are redundant and removed them all. I've tried almost every option in the map properties, the result is the same.
Section 5 - Removed Logic
Redundant Block(s):
TYPE 		BLOCK
LUT1 		dly7/buf_head
LUT1 		dly7/dly_loop[0].buf_gen
Is there any way to prevent the tool doing so?
Thanks!
Re: How to prevent the mapper to remove logics?
Please try the save attribute to prevent any ent from getting trimmed during implementation. Refer to page no 245 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/cgd.pdf .
The attribute keep is syntheis only attribute hence it doesn't have any impact during implementation.
Krishna
Krishna
Newbie irun2
It works, thanks a lot!
