Observer eita
How to solve [Place 30-675] in xczu3eg??
Hi all.
I have a problems for PnR with vivado implementation.
How can I solve this error?
I was designed serdes with IBUFGDS on 7series ZYNQ FPGA.
Now, I want to replace FPGA device 7series to Ultra scale+ MPSoC.
My device is xczu3eg on  avnet's ultrazed_eg_iocc board.
I connect IBUFGDS on RTL below.
IBUFDS #(.DQS_BIAS("FALSE"))
iob_clk_in(.I(clkin_p),.IB(clkin_n),.O(rx_clk_in_p));
BUFG iserdes_cm_bf(.I(rx_clk_in_p),.O(rx_clk_in_pc));
And start implement, become this error message.
[Place 30-675]
Sub-optimal placement for a global clock-capable IO pin and BUFG pair.If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING.  However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule.
< set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets /U_user_top/iob_clk_in/O] >
/U_user_top/iob_clk_in/IBUFCTRL_INST (IBUFCTRL.O) is locked to IOB_X2Y84
/U_user_top/iserdes_cm_bf (BUFGCE.I) is provisionally placed by clockplacer on BUFGCE_X0Y43
The above error could possibly be related to other connected instances. Following is a list of
all the related clock rules and their respective instances.
Clock Rule: rule_floating_clklds_in_half_column
Status: PASS
Rule Description: Floating ISERDESs/OSERDESs/IDELAYs/ODELAYs (ones without an associated IOB) loads
of global clock buffers like  BUFGCE/BUFGCTRL/BUFGCE_DIV must be placed such that there are not more
than 6 clock nets in an IO half bank
/U_user_top/iserdes_cm (ISERDESE3.CLK) is locked to BITSLICE_RX_TX_X0Y84
Status: PASS
/U_user_top/iserdes_cm (ISERDESE3.CLKDIV) is locked to BITSLICE_RX_TX_X0Y84
Status: PASS
/U_user_top/iserdes_cm (ISERDESE3.CLK_B) is locked to BITSLICE_RX_TX_X0Y84
Clock Rule: rule_bufgce_bufg_conflict
Status: PASS
Rule Description: Only one of the 2 available sites (BUFGCE or BUFGCE_DIV/BUFGCTRL) in a pair can be
used at the same time
and /U_user_top/iserdes_cm_bf (BUFGCE.O) is provisionally placed by clockplacer on BUFGCE_X0Y43
Also error message become on generate bit stream.
[DRC RTSTAT-2] Partially routed nets: 1 net(s) are partially routed. The problem bus(es) and/or net(s) are /U_user_top/iob_clk_in/O.
[Vivado 12-1345] Error(s) found during DRC. Bitgen not run.
After synthesis design connection below.
Re: How to solve [Place 30-675] in xczu3eg??
Hi @eita. If the CLOCK_DEDICATED_ROUTE FALSE is not working, this could be looked at with an uploaded DCP. Otherwise, did the new change resolve the issue? If so, please mark this post as resolved.
@eita,
Can you please share the post opt dcp file?
--Syed
Observer eita
Hi @syedz.
I must apologize for the delay.
I attached dcp file.
Hi @eita. There are two issues here:
  • The M2/M1 package pins are general IO and not Clock Capable pins which leads to the Place 30-675. Choosing different package pins or setting CLOCK_DEDICATED_ROUTE FALSE (not advised) will avoid the error.
  • The IBUFDS is connecting to both an IDELAYE3/IDATAIN and the BUFG. This leads to a REQP-1945 DRC error which indicates that this is an unroutable connection. The IBUFDS can only connect to IDELAYE3/IDATAIN, and not the BUFG.
REQP #1 Error The IDELAYE3 cell U_bosmina_top/U_user_top/U_sen_if/U_despara_top/U_despara_decoder/U_des/idelay_cm_m pin U_bosmina_top/U_user_top/U_sen_if/U_despara_top/U_despara_decoder/U_des/idelay_cm_m/IDATAIN attached to net U_bosmina_top/U_user_top/U_sen_if/U_despara_top/U_despara_decoder/U_des/rx_clk_in_p is also connected to other loads. This is not routable due to conflicting attributes for the net.
Observer eita
Hi @marcb.
Thank you for reply.
I added CLOCK_DEDICATED_ROUTE FALSE into constraint, but the error still become.
This is not advised method, So I take another measures.
So I will chose another package pins.
Also I refine connection of IBUFDS's output, and check results.
I think this error caused by IBUFDS's connections, by the some physical place ment constraint.
Regards.
Observer eita
Hi @marcb.
I was changed clock pin assign, and it's solved.
Thank you for advise.
Regards.
