Voyager
Voyager
How to understand routing report of selected net ?
Hi Friends,
I am facing functional issue when i add a signal(port) to ILA. and there is no issue with timing. So i want to see the routing of that net . The following info i got from vivado tcl console . am not getting exactly info reported by route_state command for selected net. Please help what to observe in this and what are those terms.
Route information for RxSkewCalHS_ln0_IBUF
Route status: ROUTED
This net is fully routed
The route tree for this net is:
Route Tree:
Subtree: 0
[{ RIOB18_X199Y164/IOB_IBUF1 (65535)
RIOI_TBYTESRC_X198Y164/RIOI_I1 ( 0) RIOI_TBYTESRC_X198Y164/RIOI_TBYTESRC.RIOI_IBUF1->RIOI_I1
RIOI_TBYTESRC_X198Y164/RIOI_ILOGIC1_D ( 0) RIOI_TBYTESRC_X198Y164/RIOI_TBYTESRC.RIOI_I1->RIOI_ILOGIC1_D
RIOI_TBYTESRC_X198Y164/IOI_ILOGIC1_O ( 0) RIOI_TBYTESRC_X198Y164/RIOI_TBYTESRC.RIOI_ILOGIC1_D->>IOI_ILOGIC1_O
RouteThru, site: ILOGIC_X1Y157 From: D To: O
RIOI_TBYTESRC_X198Y164/IOI_LOGIC_OUTS18_0 ( 0) RIOI_TBYTESRC_X198Y164/RIOI_TBYTESRC.IOI_ILOGIC1_O->>IOI_LOGIC_OUTS18_0
IO_INT_INTERFACE_R_X77Y157/INT_INTERFACE_LOGIC_OUTS18 ( 0) IO_INT_INTERFACE_R_X77Y157/IO_INT_INTERFACE_R.INT_INTERFACE_LOGIC_OUTS_B18->>INT_INTERFACE_LOGIC_OUTS18
INT_R_X77Y157/SW6BEG0 ( 7) INT_R_X77Y157/INT_R.LOGIC_OUTS18->>SW6BEG0
INT_R_X75Y153/LV18 ( 9) INT_R_X75Y153/INT_R.SW6END0->>LV18
INT_R_X75Y135/SS6BEG0 ( 9) INT_R_X75Y135/INT_R.LV0->>SS6BEG0
INT_R_X75Y129/SW6BEG0 (15) INT_R_X75Y129/INT_R.SS6END0->>SW6BEG0
INT_R_X73Y125/WW4BEG1 (17) INT_R_X73Y125/INT_R.SW6END0->>WW4BEG1
INT_R_X69Y125/SS6BEG0 (19) INT_R_X69Y125/INT_R.WW4END1->>SS6BEG0
INT_R_X69Y119/SW6BEG0 (15) INT_R_X69Y119/INT_R.SS6END0->>SW6BEG0
INT_R_X67Y115/SW2BEG0 (15) INT_R_X67Y115/INT_R.SW6END0->>SW2BEG0
INT_L_X66Y114/NL1BEG0 (14) INT_L_X66Y114/INT_L.SW2END0->>NL1BEG0
INT_L_X66Y115/BYP_ALT0 (12) INT_L_X66Y115/INT_L.NL1END0->>BYP_ALT0
INT_L_X66Y115/BYP_L0 ( 0) INT_L_X66Y115/INT_L.BYP_ALT0->>BYP_L0
}] CLBLM_L_X66Y115/CLBLM_L_AX ( 0) CLBLM_L_X66Y115/CLBLM_L.CLBLM_BYP0->CLBLM_L_AX
NOTE: Any help or suggestions are highly appreciable.
Thank you
S Sampath
Re: How to understand routing report of selected net ?
Hi @ssampath. For the specific route information on a particular net, the following command might be more useful:
get_property ROUTE [get_nets <net_name>]
This will give the routing nodes used, and can be used to compare the two versions. Also a report_timing command on the destination pin could be helpful to compare.
@ssampath
Did the shared information answered your query? If yes, then please close this thread by marking the above post which helped as "Accept as Solution"
--Syed
