ISE 10.1.03i: chipscope pro with map global optimizations
When I run map -global_opt on with a design that has a chipscope instantiation, the mapper generates the following error message:
Running global optimization...
ERROR:Map:128 - Unable to run global optimization for this design. Please rerun
   Map with global optimization disabled.
My current design has difficulty meeting timing with global opt turned off.  Is there a way to use global opt with a chipscope instantiation?
