nicosilicom
ISE 14.7 - PAR routing conflict with GLOBAL_LOGIC1
Hi everyone,
I am facing the following issue with PAR in ISE 14.7 for the part xc7k325t-1ffg900:
ERROR:Route:472 -
   This design is unrouteable.
   To evaluate the problem please use fpga_editor.
Routing Conflict 1:
	Net:inst_SGSO_PCIe/gen_V7.inst_SGSO_PCIe_Endpoint/cfg_err_cor_int_n on pin ADDRBTIEHIGH1 on location RAMB18_X3Y65
	Net:GLOBAL_LOGIC1 on pin ADDRBTIEHIGH1 on location RAMB18_X3Y64
    Conflict detected on wire: PINFEED(63874,-40949)
Routing Conflict 2:
	Net:inst_SGSO_PCIe/gen_V7.inst_SGSO_PCIe_Endpoint/cfg_err_cor_int_n on pin ADDRATIEHIGH1 on location RAMB18_X3Y65
	Net:GLOBAL_LOGIC1 on pin ADDRATIEHIGH1 on location RAMB18_X3Y64
    Conflict detected on wire: PINFEED(63890,-41397)
Routing Conflict 3:
    Conflict detected on wire: PINFEED(65661,-37000)
Routing Conflict 4:
    Conflict detected on wire: PINFEED(65661,-36936)
The signal "cfg_err_cor_int_n" is set to constant '1' in the code, through one or two inverters. The RAMB18 involved has nothing to do with the PCIe module instantiated and was automatically inferred at synthesis by XST:
First with:
Found 1024x16-bit Read Only RAM for signal <LogTable_DIn[9]_GND_3228_o_wide_mux_79_OUT>
And then with:
INFO:Xst:3226 - The RAM <Mram_LogTable_DIn[9]_GND_3228_o_wide_mux_79_OUT> will be implemented as a BLOCK RAM, absorbing the following register(s): <LogTable_Log>
| ram_type | Block | |
| Port A |
| aspect ratio | 1024-word x 16-bit | |
| mode | write-first | |
| clkA | connected to signal <i_CLOCK> | rise |
| weA | connected to signal <GND> | high |
| addrA | connected to signal <LogTable_DIn> | |
| diA | connected to signal <GND> | |
| doA | connected to signal <LogTable_Log> | |
| optimization | speed | |
If you have any suggestions, I would appreciate it!
Nicolas
vemulad
Hi @nicosilicom
The Two RAMB18s sites in a BRAM tile share ADDRATIEHIGH1 ADDRBTIEHIGH1 resources. When we place two BRAM 18s in these two sites, we need to ensure that the signal on these pins are the same. In this case, the two pins have different signal, because of which the router fails.
Try locking one of the conflicting BRAMs to a different BRAM site and see if it helps.
You can open the partially routed design in FPGA editor to find the BRAM instance which is currently sitting in site RAMB18_x3Y64.
If you need help in doing this please attach .ncd and .pcf files here.
Deepika.
Deepika.
vemulad
Hi @nicosilicom
Deepika.
Deepika.
nicosilicom
Hi @vemulad
Thanks to your indications, I found the suggestion on another post (routing conflict) to use BLKNM constraint. In fact, by using the XBLKNM constraint on one of the BRAM involved, the problem is solved.
However, the two different signals should be the same because the signal "cfg_err_cor_int_n" is equal to '1'. So, why the tool does not see that?
Nicolas
lqvshq
Hi @nicosilicom
How do you slove the problem finally? The same errors have occured to me recently,and I have no idea for it!Can you give me some suggestions,I would appreciate it!
Rowen
nicosilicom
Hi @lqvshq
The only solution I found is to direct the tool to make another placement and routing by adding or changing MAP or PAR directives, with UCF constraints, or simply with new functionalities...
I have not understand why this happens.
Nicolas
lqvshq
Hi @nicosilicom
  Thank you for your reply very much.The error of mine have caused by the combination of oddr2,iddr2 and iobuf  in order to function as a inout port in Spartan-6.It doesn't go on until the process of Place & Route after XST in the ISE 14.5.The three primitives of above can't work well in spartan-6,is it? How can I deal with the T port of tri-state gate in the iobuf.Should it be drived by oddr?
Rowen
nicosilicom
Hi @lqvshq
I think we will need more details to help you (error, report of the tool, code ...) but you should be able to use ODDR2, IDDR2 and IOBUF primitives by connecting I (Input) pin of IOBUF to ODDR2 and O (Output) pin to IDDR2.
Take care about the tri-state pin if you are redirecting it to a device pad or driving multiple IOBUF.
Did you take a look at "ug381 - Spartan-6 FPGA Selectio Resources"?
Nicolas
lqvshq
Hi @nicosilicom
The error is:
   ERROR:Route:472 - This design is unrouteable.To evaluate the problem please use fpga_editor.
Details:
ERROR:Route:472 -
Routing Conflict 1:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y68
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y68
Conflict detected on wire: PINFEED1(-105576,-86958)
Routing Conflict 2:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y70
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y70
Conflict detected on wire: PINFEED1(-105576,-76286)
Routing Conflict 3:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y72
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y72
Conflict detected on wire: PINFEED1(-105576,-66686)
Routing Conflict 4:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y74
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y74
Conflict detected on wire: PINFEED1(-105576,-57086)
Routing Conflict 5:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y69
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y69
Conflict detected on wire: PINFEED1(-105566,-86926)
Routing Conflict 6:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y71
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y71
Conflict detected on wire: PINFEED1(-105566,-76254)
Routing Conflict 7:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y73
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y73
Conflict detected on wire: PINFEED1(-105566,-66654)
Routing Conflict 8:
Net:w_clk_100m_180 on pin CLK1 on location OLOGIC_X0Y75
Net:w_clk_100m_270 on pin CLK1 on location ILOGIC_X0Y75
Conflict detected on wire: PINFEED1(-105566,-57054)
Total REAL time to Router completion: 5 secs
Total CPU time to Router completion: 4 secs
Partition Implementation Status
No Partitions were found in this design.
Generating "PAR" statistics.
Generating Clock Report
| Clock Net | Resource |Locked|Fanout|Net Skew(ns)|Max Delay(ns)|
| 0.000 | |
| w_clk_16p5m* | BUFGMUX_X2Y12| No | 64 | 0.000 | |
| w_clk_100m_270* | BUFGMUX_X2Y2| No | 14 | 0.000 | |
| w_clk_100m* | BUFGMUX_X2Y1| No | 200 icon_CONTROL0<0>* | BUFGMUX_X2Y10| No | 87 | 0.000 | |
| w_clk_100m_90* | BUFGMUX_X3Y13| No | 12 | 0.000 | |
| 0.000 | |
|u_icon/U0/iUPDATE_OU | | | | | |
| T* | Local| | 1 | 0.000 | |
| w_clk_100m_180* | BUFGMUX_X2Y4| No | 9 | | |
* Some of the Clock networks are NOT completely routed
* Net Skew is the difference between the minimum and maximum routing
only delays for the net. Note this is different from Clock Skew which
is reported in TRCE timing report. Clock Skew is the difference between
the minimum and maximum path delays which includes logic delays.
* The fanout is the number of component pins not the individual BEL loads,
for example SLICE loads not FF loads.
| icon_CONTROL1<13>* | Local| | 5 | 0.000Timing Score: 650781 (Setup: 650781, Hold: 0, Component Switching Limit: 0)
Code:
ODDR2 #(.DDR_ALIGNMENT("C1"),
.INIT(1'b0),
.SRTYPE("ASYNC")
) ODDR2_dq_out_en0
(.Q(w_dq_out_en0),
.C0(i_clk),
.C1(i_clk_180),
.CE(1'b1),
.D0(w_dq_out_en_tmp),
.D1(w_dq_out_en_tmp),
.R(1'b0),
.S(1'b0));
The oddr2 is to drive the T pin of tri-state gate,and I am not sure the reasonability of it.
io_ddr_m u_dq0(
.i_clko(i_clk),
.i_clko_180(i_clk_180),
.i_clki(i_clk_90),
.i_clki_180(i_clk_270),
.i_wr_en(r_dq_vaild),
.i_rd_en(r_data_flag),
.i_outen(w_dq_out_en0),
.i_oddr_rst(1'b0),
.i_oddr_st(1'b0),
.i_iddr_rst(1'b0),
.i_iddr_st(1'b0),
.i_d0(r_dq1[0]),
.i_d1(r_dq2[0]),
.io_dq(io_DQ[0]),
.o_di_0(w_data1[0]),
.o_di_1(w_data2[0])
The module is to function as a bidirectional pin named io_DQ,it has eight bit width.So there are eight modules in total.The net called w_dq_out_en0 is T pin.
module io_ddr_m (
input i_clko
,input i_clko_180
,input i_clki
,input i_clki_180
,input i_wr_en
,input i_rd_en
,input i_outen
,input i_oddr_rst
,input i_oddr_st
,input i_iddr_rst
,input i_iddr_st
,input i_d0
,input i_d1
,inout io_dq
,output o_di_0
,output o_di_1
wire w_oddr_q;
wire w_iobuf_q;
ODDR2 #(
.DDR_ALIGNMENT("C1"), // Sets output alignment to "NONE", "C0" or "C1"
.INIT(1'b0), // Sets initial state of the Q output to 1'b0 or 1'b1
.SRTYPE("ASYNC") // Specifies "SYNC" or "ASYNC" set/reset
) ODDR2_inst (
.Q(w_oddr_q), // 1-bit DDR output data
.C0(i_clko), // 1-bit clock input
.C1(i_clko_180), // 1-bit clock input
.CE(i_wr_en), // 1-bit clock enable input
.D0(i_d0), // 1-bit data input (associated with C0)
.D1(i_d1), // 1-bit data input (associated with C1)
.R(i_oddr_rst), // 1-bit reset input
.S(i_oddr_st) // 1-bit set input
IDDR2 #(
.INIT_Q0(1'b0), // Sets initial state of the Q0 output to 1'b0 or 1'b1
.INIT_Q1(1'b0), // Sets initial state of the Q1 output to 1'b0 or 1'b1
) IDDR2_inst0 (
.Q0(o_di_0), // 1-bit output captured with C0 clock
.Q1(o_di_1), // 1-bit output captured with C1 clock
.C0(i_clki), // 1-bit clock input
.C1(i_clki_180), // 1-bit clock input
.CE(i_rd_en), // 1-bit clock enable input
.D(w_iobuf_q), // 1-bit DDR data input
.R(i_iddr_rst), // 1-bit reset input
.S(i_iddr_st) // 1-bit set input
IOBUF #(
.DRIVE(12), // Specify the output drive strength
.IOSTANDARD("DEFAULT"), // Specify the I/O standard
.SLEW("SLOW") // Specify the output slew rate
) IOBUF_inst (
.O(w_iobuf_q), // Buffer output
.IO(io_dq), // Buffer inout port (connect directly to top-level port)
.I(w_oddr_q), // Buffer input
.T(i_outen) // 3-state enable input, high=input, low=output
endmodule
