ISE 14.7 PCI core not generated
Dear all,
My customer is having a problem with ISE 14.7.
It doesn't generate the core for the PCI.
Attached you will find:
1. the warning about the NGC not generated;
2. the error after he tries to generate the core;
3. the files generated;
The license is ok and activated and the Spartan3 is supported.
Part Number : XC3S1000-4FG456
Can you help me ?
Thanks in advance.
Andrea
回复: ISE 14.7 PCI core not generated
Hmm, this is interesting. Normally a file with .ngo extension will be generated.
If licensing is not a problem, please try renaming either of the .bought file to "pci_lc_i.ngo". Then set the -sd option in ngdbuild and re-run the flow.
It would be best to cross check the IP generation @PCI board.
This question should be posted to Implementation board since the failure is in Translate phase.
This is typically caused by the IP netlist not found. You need to open Translate properties dialog box and set the option "Macro Search Path" to point to where the IP output netlist .ngo is located.
The following AR addresses the topic:
https://www.xilinx.com/support/answers/10235.html
Dear @graces
Sorry for posting my question in the wrong place.
Thanks anyway for the help.
We checked that not even the .ngo file is generated.
Andrea
You need to set the translate property "Macro Search Path" (-sd) to <path>/verilog/src/xpci, and re-implement.
Dear @graces,
One of the problems has been resolved thanks to the first answer but about the file .ngo we still have some problems.
I'm sorry tell you again that the file .ngo is not generated.
Attached you will find a screenshot of what we got.
Our customer told us that it should generate one file named "pci_lc_i.ngo"
Not the 3 pci_lc_i.ngo.xxx but just 1.
Thanks in advance for the help.
Andrea
Dear @graces,
Thanks a lot for the help.
The problem is now fully resolved.
Maybe you even know why the file was not generated immediately at the beginning?
Even one of your assumptions is fine, it is not critical as a question since the problem has been solved.
Andrea
Glad to hear you can move on.
I'm not sure why no .ngo file was generated directly for this particular IP. I'd suggest that you post @PCI Express board if you would like to double check the IP output file.
Okey, thank you.
Andrea
