Newbie rainbowzm
ISE MAP problem
when I use ISE 13.2 to synthesize V6-240T project, if I select map global_opt option to speed, the ISE tools will halt at MAP stage, the tools runs global_opt speed optimize for long time and tools won't acess next map stage, it is hang there.
other problem is DDR3 controller, when we select global_opt for speed, it will report following error at place & route stage. and we try add "S" for these signal in UCF, it is still reporting these error.
if we disable global_opt, two oroblem will disappeared, but STA wil report timing issue.
5 signals are not completely routed.
WARNING:ParHelpers:360 - Design is not completely routed.
 u_ddr_top/u_mig_38/u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[0].u_phy_dqs_iob/dqs_p_iodelay
u_ddr_top/u_mig_38/u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[1].u_phy_dqs_iob/dqs_p_iodelay
u_ddr_top/u_mig_38/u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[2].u_phy_dqs_iob/dqs_p_iodelay
u_ddr_top/u_mig_38/u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[3].u_phy_dqs_iob/dqs_p_iodelay
u_ddr_top/u_mig_38/u_memc_ui_top/u_mem_intfc/phy_top0/u_phy_data_io/gen_dqs[4].u_phy_dqs_iob/dqs_p_iodelay
Community Manager
Community Manager
Re: ISE MAP problem
There are few knwon issues reported while using Global_opt. It will be obsolete from GenX tools.
I recommend you to not use the global_opt option.
