abdul_syed
Implement Design Error on Spartan 6 using Xilinx ISE 14.7: Constraint File Error
I have currently purchased Nexys 3 Spartan-6 FPGA Trainer Board and trying to implement a simple logic (2 inputs and 1 output) on this evaluation board.
I am new to Xilinx ISE 14.7 on Windows 10 Operating System (Oracle Virtual Machine). I have created the following constraint file (.ucf) for my circuit (see below);
NET "SW<0>" input_A LOC = "T10";
NET "SW<0>" input_A IOSTANDARD = "LVCMOS33";
NET "SW<1>" input_B LOC = "T9";
NET "SW<1>" input_B IOSTANDARD = "LVCMOS33";
NET "LED<0>" output_C LOC = "U16";
NET "LED<0>" output_C IOSTANDARD = "LVCMOS33";
I currently trying to implement a simple logic circuit with two inputs and one output. The tool has managed to successfully Synthesize but when I click and try to run the 'Implement Design' the tool states it 'Process "Translate" failed'. When I check the 'Error' tab the following error are stated;
ERROR:ConstraintSystem:300 - In file: constraints.ucf(1): Syntax error.  Ensure
   that the previous constraint specification was terminated with ';'.
ERROR:ConstraintSystem:300 - In file: constraints.ucf(2): Syntax error.  Ensure
ERROR:ConstraintSystem:300 - In file: constraints.ucf(3): Syntax error.  Ensure
ERROR:ConstraintSystem:300 - In file: constraints.ucf(4): Syntax error.  Ensure
ERROR:ConstraintSystem:300 - In file: constraints.ucf(5): Syntax error.  Ensure
ERROR:ConstraintSystem:300 - In file: constraints.ucf(6): Syntax error.  Ensure
If I comment the constraint file with then it successfully completes the implement design.
Please can you kindly assist me in solving this issue.
hongh
Hi, @abdul_syed ,
Please confirm that only one net name(port name) follow "NET" in your UCF.
Example port name "input clk_p", "input reset", "output [7:0] counter_out":
NET "clk_p"  LOC = AD12;
NET "reset" LOC = AB7;
NET "counter_out[0]" LOC = AB8;
hongh
Hi, @abdul_syed ,
abdul_syed
Hi @hongh
Many thanks for your suggestion. I have implemented the design successfully without any errors by following your suggestion.
The only problem I now facing is the VM Oracle doesn't recognize the USB connection to the evaluation board. See the attached screenshot.
Please can you advise me how I can configure the USB on the VM Oracle so that it recognize the USB connection.
Many thanks
hongh
Hi, @abdul_syed ,
Since the error in Translation is resolved, please close the current thread and create a new topic in Configuration board for your new query. The configuration expert will continue to help you.
Thank you for your cooperation and understanding.
