rothenbergt
Implementation Fails with error [Place 30-494] The design is empty and [Common 17-69]
Resolution: Check if opt_design has removed all the leaf cells of your design. Check whether you have instantiated and connected all of the top level ports.
[Common 17-69] Command failed: Placer could not place all instances
I am trying to simulate this design to synthesize and implement the design on the FPGA BASYS 3 board.
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 09/01/2018 07:35:04 PM
// Design Name:
// Module Name: Part_1_Sim
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module Part_1_Sim(
    reg Inp_1_t;
    reg Inp_2_t;
    wire Outp_t;
      Part_1 UUT (
      .Inp_1 (Inp_1_t),
      .Inp_2 (Inp_2_t),
      .Outp(Outp_t)
      initial begin
      Inp_1_t = 1'b0;
      Inp_2_t = 1'b0;
      end
    always #10 Inp_1_t = ~Inp_1_t;
    always #20 Inp_2_t = ~Inp_2_t;
endmodule
set_property PACKAGE_PIN V17 [get_ports Inp_1]
set_property PACKAGE_PIN V16 [get_ports Inp_2]
set_property PACKAGE_PIN U16 [get_ports Outp]
set_property IOSTANDARD LVCMOS33 [get_ports Inp_1]
set_property IOSTANDARD LVCMOS33 [get_ports Inp_2]
set_property IOSTANDARD LVCMOS33 [get_ports Outp]
// Company:
// Engineer:
// Create Date: 09/01/2018 07:16:12 PM
// Design Name:
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
module Part_1(
    input Inp_1,
    input Inp_2,
    output Outp
    assign Outp = Inp_1 & Inp_2;
endmodule
syedz
@rothenbergt
I am sure that you are synthesizing/implementing the test bench file which is "Part_1_Sim". Since this is a test bench file, you should not implement this module and use it only for Simulation.
Select "Part_1_Sim" file and under properties window uncheck synthesis and Implementation and check only Simulation as shown in below figure:
Now reset and rerun the complete vivado flow which should pass successfully.
--Syed
hemangd
Hi @rothenbergt,
Tried your testcase on Vivado 2018.2 with virtex 7 board and i am not facing any errors while implementation.
hemangd
hemangd
hemangd
Hi @rothenbergt,
hemangd
hemangd
syedz
@rothenbergt
--Syed
rothenbergt
Amazing! Thank you so much Syedz!
I tried your solution and now when I synthesize the file, it says "There are no HDL sources in file set 'sources_1'. Please use the Add Sources command". Can you help me?
syedz
@normal_engineer
Please create a new forum thread if you have a query. Check in the sources hierarchy if you have any HDL file and correct hierarchy.
If this is Block design then you need to create a wrapper around the BD file. Right click on BD file and select create wrapper
--Syed
MetzgerM
I had the same issue. So SIMPLE when you know what you're doing!! Thanks!
