Implementation of a synthesized DCP file and a EDF file together
I have a whole system synthesized using Vivado and is present in DCP format. In this system, there is a sub-module present(wrapper only) which is synthesized separately using another tool and is present in EDF format.
I am trying to implement both the files together, my aim being the module wrapper present inside the system DCP file should be replaced with the synthesized EDF module for implementation.
Is this possible ? Is there any way to do this in Vivado?
Please try to merge the netlist with the below commands:
open_checkpoint top.dcp
update_design -cells <inst_name> -from_file <inst>.{edf/edn}
write_checkpoint new.dcp
