Implementation setting (or strategy) to meet timing closure,
Hello.
Is there a Implementation setting (or strategy) in which implementation runs until the timing is met (there is no negative slack or no timing violance).
Thanks for your help.
Re: Implementation setting (or strategy) to meet timing closure,
Hi, @kimjaewon  ,
Yes, the Explore directive has the higher effort level than Default directive and will try different algorithm to get better timing result.
Hi, @kimjaewon ,
No. If such Implementation setting exists, the tool will hang in so many situations.
In many situations, the timing violation realted to design should be intervened with source code optimization, correcting constaints...etc.
@kimjaewon
All implementation strategies try to run until timing closure is achieved.
When implementation cannot achieve timing closure then it is usually (as hongh says) a result of problems with our coding/design.  The messages and the timing analysis reports produced by implementation help us find and correct the problems with our coding/design.
Achieving timing closure is often a difficult part of FPGA work.  When a design fails timing analysis, we often start by opening the implemented design and looking at the timing paths that have the Worst Negative Slack (WNS).
UG906 is a good document about achieving timing closure as is UG1292.
Mark
In the (Vivado) Implementation settings, I changed the Options strategy from Vivado Implementation Defaults to Performance_Explore.
Then, after I re-implemented, the negative slacks all disappeared (although the elapsed time increased).
I guess changing the settings made the difference.
Hi, @kimjaewon  ,
@kimjaewon
You were lucky this time.  Rarely, timing closure problems can be solved by only changing the implementation settings/strategy.
Mark
