RobinKao
Integrate submodule netlist into orhter project
Xilinx version: 2019
Purpose :
I want to save sub-module netlist and P&R information, and then integrate it into other project.
Q1:
I using write_verilog and add_cells_to_pblock command to get sub-module .edn and stub file at implementation stage.
But the sub-module port name and port numbers is complete different. It's hard to integrate to other project.
Do I need to keep sub-module boundary and re-synthesis and re-implementation again?
Q2:
When I write out sub-module .edn file with add_cells_to_pblock command at implementation stage. Does the .edn file contain
place & route info and the info could carried into other project?
Q3:
Do I need using OOC synthesis mode?
