tarinip
Interfacing OV7670 with Zedboard
I am trying to interface ov7670 camera with zedboard .I have used hamsters code for that . But while synthesis and implementaion getting large amount of critical warning Is it safe to Ignore?My bitstream is not getting generated its showing error in that also .I am atttaching whatever i have done.
Please help.
tarinip
Thanks for replying.I have seen that already and did what they said .Bitstream is getting generated but when i am doing program fpga It is getting programmed but its not showing output
tarinip
 I am  getting these critical warning
[Common 17-55] 'set_property' expects at least one object. ["C:/Users/admin/hoja/project_1/project_1.srcs/constrs_1/imports/hoja/zedboard.xdc":1]
Like this 40 warning
[DRC 23-20] Rule violation (NSTD-1) Unspecified I/O Standard - 46 out of 46 logical ports use I/O standard (IOSTANDARD) value 'DEFAULT', instead of a user assigned specific value. This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all I/O standards. This design will fail to generate a bitstream unless all logical ports have a user specified I/O standard value defined. To allow bitstream creation with unspecified I/O standard values (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks NSTD-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: vga_red[3:0], vga_green[3:0], vga_blue[3:0], frame_addr[18:0], frame_pixel[11:0], clk25, vga_hsync, vga_vsync.
Like this 2.
Is it safe to ignore this?
please help
nupurs
@tarinip,
Please see this AR : https://www.xilinx.com/support/answers/56354.html
Nupur
tarinip
florentw
Hi @tarinip,
This is always better to know what you are doing. So you should check what are the correct IO standard to assign for every IO and define it in the xdc file.
Florent
Florent
tarinip
Thanks for reply.I think my xdc file has correct IO standard for ever IO.Can you please go through it
florentw
Hi @tarinip,
If you could send the vivado.log file it could give more information of what is wrong.
But yes the xdc looks fine
Florent
Florent
tarinip
Hello Florent,
Thanks for replying.I am attaching my log file
Tarini
florentw
Hi @tarinip,
That is weird. It seems that your xdc file is not read... Could you check if you have the correct file in vivado (in the constraint sources, is it the one marked target?)
Florent
Florent
tarinip
Hello @florent
Thanks for replying. While generating the bitstream i was getting following error
Like this 2.
as suggested in https://www.xilinx.com/support/answers/56354.html
I did this part as my synthesis and implementation were run without error though they had critical errors
3. If you just need to generate the bit file from the existing completed Implementation run and temporarily ignore those unconstrained I/Os, use this solution
 After doing this Xdc file doesnt remain the constraint target.
What should I do?
Tarini
tarinip
This is the screenshot
tarinip
Hello @florent,
I have solved  my previous errors and I have generated  my Bitstream is generated but  when  I program using  hardware target . It's getting programmed but  not showing  the output. Instead there  are 2 warnings the debug hub vote was  not detected  at user scan chain 1or 3
1) Make sure clock  connected  to debug hub core  is in free  running clock and is active OR
2)manually launch hw_server  one
I have gone through the  https://www.xilinx.com/support/answers/64764.html
But still not getting output
 Thank you
tarinip
FPGA is programmed. To see whether the code is working, an LED0 is made to glow and after programming the FPGA, it is glowing. But the camera output is still not visible. These are the warnings that we are getting. Could you go through it?
WARNING: [Labtools 27-3123] The debug hub core was not detected at User Scan Chain 1 or 3.
Resolution:
1. Make sure the clock connected to the debug hub (dbg_hub) core is a free running clock and is active OR
2. Manually launch hw_server with -e "set xsdb-user-bscan <C_USER_SCAN_CHAIN scan_chain_number>" to detect the debug hub at User Scan Chain of 2 or 4. To determine the user scan chain setting, open the implemented design and use: get_property C_USER_SCAN_CHAIN [get_debug_cores dbg_hub].
florentw
Hi @tarinip,
Did you add an ILA in your design? If you need to start the zynq PS (in vivado run an application). Same thing if you are using a clock from the zynq
Florent
Florent
tarinip
Hello @florentw
At first I didn't have port mapping of Block memory generator. Now that I have it, it is giving the following error. Could you please go through it ?
If this port mapping is done properly then I'll be able to work on adding ILA in the design as you have suggested.
Thanks in advance .
florentw
Hi @tarinip,
You are missing the connent of blk_mem_gen. You need to add the sources corresponding.
Florent
Florent
tarinip
Hello @florentw
 I tried to do that but still showing error .Could you please suggest how to do that?
florentw
Hi @tarinip,
Well... "Add sources"... This is the only thing I see to do that.
Florent
Florent
tarinip
Hello @florentw,
I tried that only but its not going
Thank you
florentw
@tarinip,
What is your input format? xci, vhd, v?
You have a block design, what is inside?
Florent
Florent
tarinip
Hello @florentw
Its vhd file .Could please go through the screenshot
Thank you
tarinip
Hello
screenshot
florentw
Hi @tarinip,
I think the blk_mem_gen and xilinx_frame_buffer are xilinx IPs you need to generate (or add the xci files). Do you have any information? Where did you get the sources?
Florent
Florent
tarinip
Hello @florentw
Frame buffer is not xilinx ip but Block memory generator is the xilinx IP .I got sources from
http://hamsterworks.co.nz/mediawiki/index.php/Zedboard_OV7670
Thank you
florentw
HI @tarinip,
The sources are for ISE not for Vivado. That is probably why you have issues in your project.
The best way to start is maybe to start with ISE and when it is working then move to Vivado.
Or search for another example project made with vivado:
https://lauri.võsandi.com/hdl/zynq/zybo-ov7670-to-vga.html or http://www.instructables.com/id/Connect-Camera-to-Zybo-Board/ for example
Florent
Florent
tarinip
Hello @florentw
I have gone through http://www.instructables.com/id/Connect-Camera-to-Zybo-Board
the codes in this are almost same to that of hamesters.I tried with that also but still its showing the same error
Thank you
florentw
Hi @tarinip,
Did you add the block memory generator IP? Do you see it in the sources? Is it the correct name?
Florent
Florent
tarinip
Hello@florent,
I tried to solve that problem . But  i m getting another problem while implementing  .Could you please go through it
florentw
Hi @tarinip,
Your screenshot contains an older version of the synthesized design. Could you reload it?
Florent
Florent
tarinip
Hello @florentw
Here is reloaded design and error in implementation
