Voyager
Voyager
Internal LVDS termination with bias
I'm working on a PCB with an AC coupled LVDS clock input to my FPGA.
The designer forgot to connect the DC bias and termination resistors.
Can this be done internally ?
What's the XDC syntax for the resistors ?
I am just finding that unlike 7-Series, UltraScale has DQS_BIAS (pg69, UG571), which provides a DC bias of VCCO/2 to both the P and N sides of the LVDS input buffer – but only for AC-coupled LVDS in HP banks (just what you need).
set_property DQS_BIAS TRUE [get_ports <port_name>]
According to Table 1-55 of UG571, DQS_BIAS and DIFF_TERM_ADV can both be used in HP banks.
set_property DIFF_TERM_ADV TERM_100 [get_ports <port_name>]
I find no warnings that DQS_BIAS and DIFF_TERM_ADV cannot be used together.  Table 1-56 in UG571 shows some restrictions when using DQS_BIAS and EQUALIZATION.
@shaikon
In 7-Series FPGAs, the LVDS standard is only available in HP I/O banks and requires VCCO=1.8V (UG471, ~pg91).  Although an internal 100-ohm termination can be activated for LVDS, there is no FPGA internal bias voltage (as shown in your sketch).  A method of creating the bias, VICM, for AC-coupled LVDS is shown by Figure 1-72 in UG471, which uses resistors external to the FPGA.
You might be able to use the 7-Series IO standard called DIFF_SSTL18_II_DCI to bias and receive your AC-coupled LVDS.  DIFF_SSTL18_II_DCI is available in HP I/O banks and is described nicely by Figure 1-60 in UG471, which shows that split-termination resistors internal to the FPGA can be activated to bias each LVDS line to VCCO/2.  On about pages 27-28 of UG471, DIFF_SSTL18_II_DCI and the split-termination resistors are further described.
From Table 13 in the Kintex-7 datasheet (DS182), the output specifications for LVDS are VOCM=1.000-1.425V and VODIFF=0.247-0.600V.   These specifications seem to fit nicely with the input specifications for DIFF_SSTL18_II from Table 11 of DS182: VICM=0.300-1.425V and VIDIFF=0.100V(min).
I havn’t used DIFF_SSTL18_II_DCI to receive LVDS signals – but if you're in a pinch – it may be worth considering and trying.
Mark
Voyager
Voyager
I'm using a Kintex Ultrascale FPGA. Not 7 series...
Things seem pretty much the same for 7-Series and Ultrascale.  -see Fig 1-68 in UG571 and Tables 13 and 19 in DS892.
