Inverted clock for SPI
Hi all,
I have to implement the sources from an ASIC design in a FPGA for rapid prototyping. My ASIC colleagues use for an SPI implementation sck and sck_n. The inverted clock is just used for a few registers. The design is syntactically correct and I can see the RTL after the elaboration phase:
One requirement is not to change the ASIC VHDL sources of course. The spi_sck is a clock capable pin. So my question is, if it is valid to to the following thing:
sck_n <= not sck;
-- design instantation
spi_core_inst : entity work.spi_core
port map (
    sck <= sck;
    sck_n <= sck_n
I think this should be valid, because every slice can invert the clock, so is this done by the synthesis tool automatically?
I run synthesis and implementation and post here a screenshot from implementation view:
So I think this is exactly what I expected. Nonetheless I would like to know if this is a flow Xilinx recommends. As already told I cannot modify the VHDL files from the ASIC designers because we want to prototype exactly that sources in the FPGA. So the output really looks good (IS_C_INVERTED) and I would like to proceed with this workflow.
Kind regards
Sebastian
Re: Inverted clock for SPI
@sebastian_z,
Yes, this looks correct. Try running post synthesis functional simulation and see the functionality.
IS_C_INVERTED specifies the polarity on clock pin.
--Syed
