LVDS clock
Hello
I have reviewed about IBUFGDS but please help me in coding:
It's a simple LED blinker with a LVDS clock.
actually my clock is LVDS, I have created a module in a separated source as following:
(I don't know how I should use such primitive cores in my design!)
module LVDS_clk_rcvr(
      pin_clk_p,
      pin_clk_n,
      clk_int
     input pin_clk_p,
           pin_clk_n;
     output clk_int;
endmodule
IBUFGDS #(
    .DIFF_TERM("TRUE"), // Differential Termination
    .IBUF_LOW_PWR("TRUE"), // Low power="TRUE", Highest performance="FALSE"
    .IOSTANDARD("DEFAULT") // Specify the input I/O standard
) IBUFGDS_inst (
    .O(clk_int), // Clock buffer output
    .I(pin_clk_p), // Diff_p clock buffer input (connect directly to top-level port)
    .IB(pin_clk_n) // Diff_n clock buffer input (connect directly to top-level port)
on the other hand I have created a top module:
module top (switches,leds,clk_int);
    input  [3:0] switches;
    input  clk_int;
    output [3:0] leds;
    wire   dev_freq;
LVDS_clk_rcvr LVDS_clk_rcvr_1(
Freq_div u1 (clk_int,dev_freq,{switches[0],switches[1]}); Direction_ctrl u2 ({switches[2],switches[3]},leds,dev_freq); endmodule
I really I don't know how I should use this primitive core. I'm really puzzled. I'm newbie please help me clear :)
Best Regards
Tags (2)
Re: LVDS clock
@xzsawq21
Use IBUFDS instead of IBUFGDS which can be used for any port type including clock. Check this link
If you want to use IBUFDS then you need to have differential clock at the top module. The code should something be similar to :
module top (switches,leds,clk_int_p,clk_int_n);
input clk_int_p;
input clk_int_n;
output [3:0] leds;
wire dev_freq;
wire clk_int;
IBUFDS #(
.DIFF_TERM("FALSE"), // Differential Termination
) IBUFDS_inst (
.O(clk_int), // Buffer output
.I(clk_int_p), // Diff_p buffer input (connect directly to top-level port)
.IB(clk_int_n) // Diff_n buffer input (connect directly to top-level port)
endmodule
--Syed
Re: LVDS clock
@xzsawq21
input clk_int_p;
input clk_int_n;
output [3:0] leds;
wire dev_freq;
wire clk_int;
IBUFDS #(
) IBUFDS_inst (
endmodule
--Syed
