Map Error Pack:2529 with IDDR2 on Spartan 6
Hi folks!
After successfully implementing my design on two package versions of the xc6slx150t, time has come to the third one : fgg676.
I'm getting seriously weird errors during map process:
Started : "Map".
Running map...
Command Line: map -filter "c:/Documents and Settings/mapedd/Pulpit/GIT/INREVIUM_DEV_KIT/iseconfig/filter.filter" -intstyle ise -p xc6slx150t-fgg676-3 -w -logic_opt off -ol high -t 1 -xt 0 -register_duplication off -r 4 -global_opt off -mt off -ir off -pr off -lc off -power off -o m_inrevium_top_map.ncd m_inrevium_top.ngd m_inrevium_top.pcf
Using target part "6slx150tfgg676-3".
Mapping design into LUTs...
WARNING:MapLib:701 - Signal clk_in_p<2> connected to top level port clk_in_p<2>
   has been removed.
WARNING:MapLib:701 - Signal clk_in_n<3> connected to top level port clk_in_n<3>
   has been removed.
WARNING:MapLib:701 - Signal clk_in_p<4> connected to top level port clk_in_p<4>
   has been removed.
WARNING:MapLib:701 - Signal clk_in_n<5> connected to top level port clk_in_n<5>
   has been removed.
WARNING:MapLib:701 - Signal clk_in_p<6> connected to top level port clk_in_p<6>
   has been removed.
WARNING:MapLib:701 - Signal clk_in_n<7> connected to top level port clk_in_n<7>
   has been removed.
Running directed packing...
ERROR:Pack:2529 - The dual data rate register
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[10].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[9].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[12].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[14].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[8].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[11].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[13].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
   "data_buffer_inst/data_standarizer/data_rx_inst/gen_ser2par[15].inst_ser2par/inst_iddr" failed to join an ILOGIC component as required.
Mapping completed.
See MAP report file "m_inrevium_top_map.mrp" for details.
Problem encountered during the packing phase.
Design Summary
Number of errors   :   8
Number of warnings :   6
 I've googled around for this error but it was fruitless:(
Does any one have some insight what can cause this error to occure?
Thanks for any help!
i've attached my design for a reference
Re: Map Error Pack:2529 with IDDR2 on Spartan 6
I was using an internal tool to trace logic in the NGD. I recommend that you use PlanAhead to examine the netlist connectivity.
For the first error I'm seeing (by tracing logic in NGD file) that the IDDR2 has no pad connectivity. It is driven by an IODELAY and the IODELAY has constants on it's inputs. Is this what you are expecting?
Of course not:)
They should be connected to an input port of the device
Wrong NET locations in the UCF file may be the problem?
Thanks!
UCF constraints don't affect the connectivity which is determined upsteam by the synthesis tool.
ok , so there probably somethings wrong with the connections inside my HDL...
How can i inspect NGD file to find unconnected blocks?
i found the problem, some pins inside the HDL weren't connected, thanks for help!
