iafo1
Mapping and Routing on remote computer
Hallo!
I would like to map and route my projects on a remote computer. Actually I did it using map and par command lines but now I want to import the files generated back on my computer and use them with ISE GUI...
I tried to copy them in the project-directory and  force UP-to-DATE the processes I executed on remote computer but, for example, if I try to run the FPGA editor an error message tells me that I have to run the Place & Route process...
What can I do it?
Thanks...
evgenis1
Advisor
Advisor
Do you really need to run ISE GUI after place and route ?
Why cannot you just open FPGA Editor or Timing Analyzer as a stand alone application to analyze the results.
Evgeni
bwade
Are the machines on the same network with access to a common project directory? Most people use a remote desktop tool like VNC or X-Win32 to run the tools (GUI or command line) on a remote machine. Then if there's a common project directory there's no need to copy the result.
iafo1
Yes, I considered this solution...but anyway I'd like to do it... there is some document where I can read how to solve this problem?
evgenis1
Advisor
Advisor
Evgeni
