chowderii
Need help fixing OPT 31-67 ALUT3 Cell is missing a connection on input pin I0
As title suggests, I have this error when I run implementation on my design :
[Opt 31-67] Problem: A LUT3 cell in the design is missing a connection on input pin I0, which is used by the LUT equation. This pin has either been left unconnected in the design or the connection was removed due to the trimming of unused logic. The LUT cell name is: design_2_i/toplevel_ssdmobilene_0/U0/iterations_controller/num_slice_to_fill[10]_i_1.
 AR# 72980 suggests to look at the connection schematic to see for a missing connection but it is connected in my case.
Thanks!
hongh
Please expand hier module "test_slave_lite_0" to see whether there is a primitive as a driver.
hongh
syedz
@chowderii
Check this answer record to debug and resolve the error:  https://www.xilinx.com/support/answers/72980.html
--Syed
chowderii
This is the answer that helped me. I mis-wired one of the registers from the AXI_Lite interface which caused the port to not be connected to anything.
Thank you!
