Optimization design failure for my own IP with sub-referenced xilinx IPs
Hello!
Vivado 2016.4, Windows
There is my architecture "norm" with Multiplier 12.0 core (not Out-Of-Context). There is its instantiation:
  norm_i : norm_mult
  port map (
    clk => clk,
    a   => shr_iv,
    b   => sq_vl,
    p   => norm_iv
  norm_q : norm_mult
  port map (
    clk => clk,
    a   => shr_qv,
    b   => sq_vl,
    p   => norm_qv
I add sub-reference source into IP constructor and pack it into IP. I create another project and add "norm" as IP in Block design. There is "successful" status of "norm" IP in synthesis report. But when I run Implementation there is failure in opt-design stage with this error:
[DRC 23-20] Rule violation (INBB-3) Black Box Instances - Cell 'mb_system_i/norm_0/U0/norm_i' of type 'mb_system_i/norm_0/U0/norm_q/norm_mult' has undefined contents and is considered a black box.  The contents of this cell must be defined for opt_design to complete successfully.
What is the actual cause of this failure? How can I fix it?
Re: Optimization design failure for my own IP with sub-referenced xilinx IPs
@xsilverx,
Is it possible for you to share the design? If yes, then I will send you a private message where you can upload this design.
--Syed
Is it enough to send only packed "norm" IP with sources?
