resalmon
Output ports are not found when implementing design
Hello all,
I have a strange problem. I'm trying to implement a reference design for Zynq. I attached axi_gpio port to my PS. And now I want to connect it to pins connected to LEDs present on my Zynq Mini-ITX board. I'm copying this part of design from a standard design for my board (Embedded Standalone OS (Bare-Metal) Reference Design ITX) from here:
http://zedboard.org/support/design/2056/17
I'm attaching a screenshot of my connections.
I have also copied .xdc entries from that design and pasted them to a new .xdc:
set_property LOC C6 [ get_ports LEDs_8Bits_tri_o[0]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[0]]
set_property LOC B6 [ get_ports LEDs_8Bits_tri_o[1]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[1]]
set_property LOC L9 [ get_ports LEDs_8Bits_tri_o[2]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[2]]
set_property LOC L10 [ get_ports LEDs_8Bits_tri_o[3]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[3]]
set_property LOC K10 [ get_ports LEDs_8Bits_tri_o[4]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[4]]
set_property LOC K11 [ get_ports LEDs_8Bits_tri_o[5]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[5]]
set_property LOC L12 [ get_ports LEDs_8Bits_tri_o[6]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[6]]
set_property LOC K12 [ get_ports LEDs_8Bits_tri_o[7]]
set_property IOSTANDARD LVCMOS15 [ get_ports LEDs_8Bits_tri_o[7]]
But when synthesising and implementing my design Vivado gives critical warnings on each line of my .xdc:
[Common 17-55] 'set_property' expects at least one object.
What am I doing wrong?
resalmon
Well, I just had to regenerate HDL wrapper so that my signals could appear is schematics
pulim
Can you run get_ports after opening synthesized design and see if you see can this ports in the output?
If you can see the ports compare the port names with the names given in XDC.
If they don't match please corrcet them.
Check this related article,http://www.xilinx.com/support/answers/56169.html
yenigal
The names specified in the constraint file and the design are not matching.
Correct them.
Satish
resalmon
I'm running get_ports and I can't even see the ports I've created in my design. But those ports are listed in design hierarchy. I've checked dozens of times - their names match with those listed in .xdc.
I just right-buttoned the GPIO group (on the pic above) and pressed 'Make external'. Is that right?
resalmon
