PCIE Core Constrait Problems
I'm using a Virtex7 FPGA 458T when I genereate the PCIE GEN 2 8 lane core in Vivado i automatically has an .xdc file that places my transceivers in a location I don't want them to be. I want them on
MGT_117 and MGT116
but it is placing it in
MGT117 and MGT118
I place a LOC constraint in my xdc file but it gets an error:
[Vivado 12-2285] Cannot set LOC property of instance '....gtx_channel.gtxe2_channel_i', Instance ...i/gtx_channel.gtxe2_channel_i can not be placed in GTXE2_CHANNEL of site GTXE2_CHANNEL_X1Y19 because the bel is occupied by .gtxe2_channel_i. This could be caused by bel constraint conflict ["_pci_nn_485t_vivado.xdc":100]
The PCIE wizards should allow you to select MGTs but it doesn't. How do I tell vivado to ignore the .xci genereated and use the xdc file on my toplevel instead?
Without having to remove the .xci file and adding all source by hand.
You can disable the .xdc inside the IP and copy/modify it and add it to the project. You may need to add a SCOPED_TO_REF/CELLS to the xdc or modify the hierarchical paths to match your design's.
https://tuxengineering.com
