Pack:2515 XST kept optimizing my output enable
I have a bus of tristate buffer output out of a Virtex-6 FPGA.  The output enable is the same for all 8 bits of this bus.
My original code:
assign phy0_data_in[7:0]        = dataoe[0] ? datain[7:0] : 8'bz;
I tried:
assign phy0_data_in[7:0]        = {8{dataoe[0]}} ? datain[7:0] : 8'bz;
but xst optimized the dataoe to be 1 signal outside the IOB.
I tried making a bus for the dataoe and adding a KEEP attribute to it, but still optimized it away.
Full warning message:
WARNING:Pack:2515  - The LUT-1 inverter "][419045_11_INV_0" failed to join the
   OLOGIC comp matched to output buffer "phy1_data_in_2_IOBUF/OBUFT".  This may
   result in suboptimal timing.  The LUT-1 inverter ][419045_11_INV_0 drives
   multiple loads.
and it gave this warning for each data it of my bus.
I unchecked "Equivalent Register Removal" and it still optimized it away.
Any suggestions?
Instructor
Instructor
Re: Pack:2515 XST kept optimizing my output enable
This has nothing to do with registers.
The output buffer enable signal is asserted (for enable) LOW, not HIGH.  There is no logic in the IOB to invert the dataoe signal, the inversion must be in the FPGA fabric.
So here is an alternate implementation which *may* work.
(* IOB="TRUE" *)
reg [7:0]  data_in=0;
(* IOB="TRUE" *)
reg [7:0]  data_disa=0;
assign data_disa_prereg = ~dataoe;  // invert before register
always @(posedge clock)
  begin
    data_in <= data_in_prereg;  // this register will be located in the IOB
    data_disa <= {8{data_disa_prereg}}; // this register will be located in the IOB
  end
generate   // tri-state output, code copied from Gabor (gszakacs)
genvar i;  // nasty generate block to instantiate 8 tri-state controls for 8 bits
  for (i = 0;i < 8; i = i + 1)
    begin : IO_BUFS
      assign data_disa[i] = phy0_data_in[i] ? 1'bz : datain[i];
    end
endgenerate
I haven't tried this, it's a bit brute force, but it should work (or almost work).
-- Bob Elkind
SIGNATURE:
Summary:
Instructor
Instructor
(* IOB="TRUE" *)
(* IOB="TRUE" *)
  begin
  end
    begin : IO_BUFS
    end
endgenerate
-- Bob Elkind
SIGNATURE:
Summary:
Professor
Professor
I've found that the more recent versions of ISE will automatically replicate the tristate register,
and handle the inversion (similar to register balancing - i.e. the inversion needs to be at the
D side of the flip-flop) for the T register.  It really sounds like the enable function itself is not
coming from a register, but from combinatorial logic that can't be pushed into the IOB.  As long
as the output enable comes directly from a register, then pushing it into the IOB should work.
-- Gabor
-- Gabor
Hmm. I am using an older version (11.4), but it has been working for all this time, I don't want to upgrade :)
The oe is coming straight from a register, so I'm trying Bob's suggestion right now and replicating it.
Prior to posting, I did try using generate & didn't work.
Thanks for the responses!
