Pin Assignments In Vivado For Block Designs
Im migrating from ISE to Vivado to program the Artix AC701 board.
Im following https://www.xilinx.com/video/technology/dma-for-pci-express.html to make a block design in Vivado to connect the DMA and MIG blocks and generate a programmable bitstream.
In ISE theres usually one UCF for the pin assignments but it seems in vivado each IP generates internal constraint files.
My question is when the bitstream is generated from a block design, will it automatically assign the internal constraint files to the right pins for the development board in the multiple internal constraint files?
Cheers
-P
Re: Pin Assignments In Vivado For Block Designs
Hi @petersanch
IP xdc is read before the user xdc if you set  PROCESSING_ORDER property of IP xdc to Early. The option you can select based on your requirement/ scenario. For detail information refer the below link, page 14:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug903-vivado-using-constraints.pdf
IP physical constraints should be properly applied to their intended objects pins as long as we are not specifying the same constraints for the object pins in the top level xdc. To verify you can see the IO ports window once you open the implemented design.
Rohit
Rohit
Yes, the tool will utilize the internal IP constraints (which are demo board specific) and assign them to its pins. Naturally the part selected for the project should be the correct demonstration board. You can verify the pin assignments by opening up the implementation and reviewing the I/O assignments and compare them to the constraint files.
Hi @petersanch
Rohit
Rohit
Thanks logictable and thakurr.
I'm new to Vivado and dont know where to search for IO ports window under Implementation.
This is what I see under implementation.
And these are the tabs.
Cheers
-P
Hi @petersanch
Once you complete implementation, open implemented design, at bottom you will see I/O ports window as shown below:
Rohit
Rohit
Hi thakurr.
I changed the layout to I/O Planning then the IO Ports showed. Cheers!
Hi @petersanch
Please do close the thread by marking the helpful post as accepted solution.This could prove be beneficial for future users for reference.
Rohit
Rohit
