Place 30-4 Error
I'm running into the follwoing error and I can't find any documentation to solve the probelm.  My design is targeted at a Zynq7020 and the placer fails to even attempt to fit the design.  Here is the exact error:
[Place 30-4] Design utilization is very high. Run report_utilization command to see design utilization. Abandoning placement as chances are very low that placement is possible. To skip this check run placement with 'place.skipUtilizationCheck' parameter set.
Anyone know where this is documented, or how to fix it?
Thanks in advance.
Adam
Hi @snikrepmada-athena
You can try the parameter suggested in the error message
set_param place.skipUtilizationCheck 1
Run the above command in Vivado TCL console and rerun Implementation.
Deepika.
Deepika.
Open synthesized design and run report_utilization command from TCL console.
Check if there are any resources which are highly utilized. Attach the log here if possible.
Deepika.
Deepika.
Hello @vemulad,
Thank for the quick reply.  My utilization of resources is semi-high, the flip-flops are at 79% and the LUTs are at 61%.  I know the design will fit but, I can't figure out how to override the utilization check there does not seem to be an entry to ignore that check in the implementation settings and I cna't find a reference to it in the TCL documentation.
Respectfully,
Adam
Deepika.
Deepika.
@vemulad
Thank you very much for your help.
