PlanAhead: Implementing a static-only design
I had trouble with a PR design, so I'm trying to take a step back and implement it under the same conditions, but without the PR constraints. I'm trying to use the same tool (PlanAhead) to keep as many variables as possible the same.
I have an .ngc , .edf and .ucf that I am trying to use, but initially I cannot create a design run with static logic only.
However, I have had some luck, by marking the .edf as a partition, then removing it as a partiton. After this I have the option of creating a design run with static only logic. I created the bit file and it seems to work as desired. So is this functionality allowed in PlanAhead and what is the proper way to accomplish it?
Re: PlanAhead: Implementing a static-only design
Yes, PlanAhead can run the flat flow. What problem are you having with that flow?
When I add my base design (.ngc), my constraints (.ucf) and a netlist that goes with the design (.edf) I can not run implementation. If I try, it thinks for a couple seconds and then is done, but doesn't give me an error. If I look in the "Implementation Run Properties" there are no modules under "Partitions". Why is it missing the static module? Is there a step I need to do to generate this?
Would it help if I gave more details?
This sounds more like a PlanAhead usage issue than an Implementation Tool issue. You might try the Design Entry forum. You could also open a webcase.
