nagi12
Regarding i/o pins
hello,
suppose if nearly 200 i/o pins your design, how to assign an input and port ports in your i/o planning schematic.
Thank You
Nagi
rshekhaw
Hi @nagi12 ,
In addition to Hong post, please check this Video on IO planning:
https://www.xilinx.com/video/hardware/i-and-o-planning-overview.html
Raj
hongh
Hi, @nagi12 ,
If your board has been designed, you can assign Package Pin to IO by referring to UG899  (I/O Planning part)
If your just need to have a test, you can run synth/impl directly and read the Package Pin property back.
rshekhaw
Hi @nagi12 ,
Raj
