Observer sabiya
Route design error
I implemented a display port transmitter on xczu9eg-ffvc900-1-e (active) board part. I got below error in buffers.
Observer sabiya
Re: Route design error
please help me. I got a error in differential clock.
Teacher drjohnsmith
have you gone through this
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug949-vivado-design-methodology.pdf
From what you have showen us, you have some IO pins in the desgn that you XDC has mapped to pins that do not exist / or can not support the standard or function you intend.
Look in the tcl window to see where the first error is .
Hi @sabiya ,
Try routing the failing nets manually by using route_design -nets command and see if it is able to route.
route_design -nets [get_nets dp_tx/display_tx_/util_ds_buf_1/U0/IBUF_OUT[0]]
Raj
