poornima_95
[Shape builder 18-119] Failed to create I/O LOGIC Route through shape for instance design_testjig_wrapper_inst/design_testjig_i/axi_ethernet_1/inst/eth_mac/inst/rgmii_interface/rgmii_rx_ctl_ibuf_i
Hi All,
I am getting a critical warning for the Ethernet instances.
[Shape Builder 18-119] Failed to create I/OLOGIC Route Through shape for instance design_testjig_wrapper_inst/design_testjig_i/axi_ethernet_1/inst/eth_mac/inst/rgmii_interface/rgmii_rx_ctl_ibuf_i. Found overlapping instances within the shape: design_testjig_wrapper_inst/design_testjig_i/axi_ethernet_0/inst/eth_mac/inst/tri_mode_ethernet_mac_i/rgmii_interface/rgmii_rx_ctl_ibuf_i and design_testjig_wrapper_inst/design_testjig_i/axi_ethernet_1/inst/eth_mac/inst/rgmii_interface/rgmii_rx_ctl_ibuf_i.
my design has two 1G/2.5G Ethernet subsytem,where one is included shared logic in core and second one is included shared logic in example design.please find the attached snapshot of the design below.
Please help me to understand why i am getting this warning and How can i solve this.
Thank You.
marcb
Hi @poornima_95. Is the target part a 7-Series device? The message looks to indicate so, but I wanted to confirm. Also, can you indicate what type of primitives the two instances in the message are?
A shape is an internally generated relatively placed macro that is intended to assist place_design. IO instances would need to have the correct relative coordinates. This message would indicate that there is overlap within the shape. I would try checking if the two cores have conflicting IO constraints.
marcb
poornima_95
Hi@marcb ,
Thank you for your reply. I have already solved this warning, as you said it was because of the conflicting IO constraints. the two rx_clk buffers were overlapping.
 and yes the target is 7 series device.
