The register failed to join a ILOGIC2 component as required.
hai please give me any suggessions how to rectify my error. while mapping i got this error
ERROR:Pack:2541 - The register "U_ila_pro_0/U0/I_TQ0.G_TW[40].U_TQ" failed to
Re: The register failed to join a ILOGIC2 component as required.
Hi harinatha.reddy@eldaas.com ,
Which device family are you working with?
As per my understanding the error message it is conveying that it can't route from ILOGIC2 to U_ila_pro_0/U0/I_TQ0.G_TW[40].U_TQ.
Check the IO select USer guide of the particular device, and check that the instantiation are correctly mapped.
Raj
thank you for your suggession. i am using spartan 6
Can you please share the instantiation code to which the error is pointing?
Raj
ok sir, please find the attached file
Are you adding an ILA probe on the input to logic that is contained within the ILOGIC site? These should be dedicated connections, and would not be able to physically handle another path. Can you probe the output instead?
No sir i didn't added any ILA probe
Can you check to see what the pin to pin connectivity is of the signal listed in the error "U_ila_pro_0/U0/I_TQ0.G_TW[40].U_TQ"? I would upload a schematic of this. How is this signal added as well?
