khyu
Timing critical module keep last implementation
 I have the critical design USB3 that run at 125Mhz.
The FPGA timing is very critical .
If I have some little change , for example
TOPA--USB3A  => TOPB--USB3B
Critical Timing get worse and unstable
Can I keep USB3A  implementation layout and only modified part USB3A-USB3B is placed and routed?
syedz
@khyu
You can try Incremental implementation with Vivado. Check page 101 in below user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug904-vivado-implementation.pdf
--Syed
syedz
@khyu
--Syed
