Ultra96-V2 constraints error
Hi!
I want to try the Ultra96-V2 board and I have made a design in Vivado where I just set the user leds to "0100". I have downloaded the constraints file from https://www.avnet.com/wps/portal/us/products/avnet-boards/avnet-board-families/ultra96-v2/ and following it I have added these lines to the io.xdc:
set_property PACKAGE_PIN AB4 [get_ports "leds[0]"];
set_property PACKAGE_PIN AA4 [get_ports "leds[1]"];
set_property PACKAGE_PIN Y5 [get_ports "leds[2]"];
set_property PACKAGE_PIN AA3 [get_ports "leds[3]"];
set_property IOSTANDARD LVCMOS18 [get_ports "leds[0]"];
set_property IOSTANDARD LVCMOS18 [get_ports "leds[1]"];
set_property IOSTANDARD LVCMOS18 [get_ports "leds[2]"];
set_property IOSTANDARD LVCMOS18 [get_ports "leds[3]"];
But I get an error:
[Place 30-494] The design is empty
Resolution: Check if opt_design has removed all the leaf cells of your design. Check whether you have instantiated and connected all of the top level ports.
And 16 warnings like this:
[Common 17-55] 'set_property' expects at least one object. [io.xdc":1]
Does anyone know how to solve this?
Thank you
florentw
Hi alonsosara44@gmail.com
What is your design?
It seems that the design has been optimised so the implementation tool cannot find the port called "leds"
Florent
