syedz
UltraFast Design Methodology Overview
Xilinx has created comprehensive UltraFast Design Methodology Guides that cover key principles, specific do's and don'ts, best practices, and ways to avoid pitfalls. In some topics, Xilinx provide real life use cases to illustrate concepts. The methodologies presented is a reflection of user experiences and learning gained from system development inside and outside of Xilinx.
The Implementation section outlines the tips and tricks to eliminate specific bottlenecks that many customer have run into on their journey.  It also outlines when to use different attributes, properties, and physical constraints.
Download the new UltraFast High-Level Design Methodology Guide today!
