[Vivado 2016.4] An unexpected error has occurred (11)
recently I started getting following error.
I get the error again if restart design implementation (not sure if always).
When I rebooted pc (not sure if changed anything in the project) implementation succeeded.
Implementation takes quite some time, so I don't know if there is something that fixes the problem.
I'm also attaching implementation log.
# An unexpected error has occurred (11)
Stack:
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7ff0417924b0]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_device.so(HDPDUniqueHDDMArcNodes::convHDMMArcNodeToLong(HDDMArcNode const&)+0x16) [0x7ff0261f6746]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_device.so(HDPDUniqueHDDMArcNodes::getNodeIndex(HDDMArcNode const&)+0x9) [0x7ff0261f6a39]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_device.so(HDPDESiteClkDlyTable::getNearestBranchingNode(HDDMArcNode const&, HDDMArcNode&) const+0x17) [0x7ff0261f7eb7]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_timing.so(HASTNCNDelays8Impl::dfs(HDDMPin&, HDDMArcNode&, std::map<HDDMArcNode const, HASTArcNode*, HASTNCNDelays8Impl::HDDMArcNodeLess, std::allocator<std::pair<HDDMArcNode const, HASTArcNode*> > >&, std::map<HDDMArcNode const, HASTArcNode*, HASTNCNDelays8Impl::HDDMArcNodeLess, std::allocator<std::pair<HDDMArcNode const, HASTArcNode*> > >&)+0xe3) [0x7ff01a475a83]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_timing.so(HASTNCNDelays8Impl::dfs(HDDMPin&, HDDMArcNode&, std::map<HDDMArcNode const, HASTArcNode*, HASTNCNDelays8Impl::HDDMArcNodeLess, std::allocator<std::pair<HDDMArcNode const, HASTArcNode*> > >&, std::map<HDDMArcNode const, HASTArcNode*, HASTNCNDelays8Impl::HDDMArcNodeLess, std::allocator<std::pair<HDDMArcNode const, HASTArcNode*> > >&)+0x859) [0x7ff01a4761f9]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_timing.so(HASTNCNDelays8Impl::cacheNodeDelays(HADEDlyMediator const*, HDLHNet const*, std::vector<std::pair<HDLHInstTerm const*, HDDSArcDlyVal*>, std::allocator<std::pair<HDLHInstTerm const*, HDDSArcDlyVal*> > >&)+0xf1f) [0x7ff01a479c1f]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_timing.so(HAST3Sta::cacheNCNEstimatesForUnroutedNets(sta::Vertex*, HDLHInstTerm const*, HDLHNet const*, std::vector<HADEDlyMediatorPacket, std::allocator<HADEDlyMediatorPacket> >&)+0x1a2) [0x7ff01a66d242]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_timing.so(HAST3Sta::setWireDelayOnVertex(sta::Vertex*, std::deque<sta::Edge*, std::allocator<sta::Edge*> > const*, HAST3TimingParams const&)+0x4c5) [0x7ff01a66d8c5]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_timing.so(void* HCTThreadUtils::forEachStart<std::_Deque_iterator<std::pair<sta::Vertex*, unsigned int>, std::pair<sta::Vertex*, unsigned int>&, std::pair<sta::Vertex*, unsigned int>*>, boost::function<void (std::pair<sta::Vertex*, unsigned int>&)> >(void*)+0xf7) [0x7ff01a67d147]
/home/gumas/opt/Vivado/2016.4/lib/lnx64.o/librdi_common.so(HCTWorkingThread::threadStart(void*)+0x7c) [0x7ff04287e4ac]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7ff04123e6ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7ff0418643dd]
Re: [Vivado 2016.4] An unexpected error has occurred (11)
@gumas,
Is it possible for you to test this in latest vivado 2017.3? Also check this general AR on Vivado crash:
https://www.xilinx.com/support/answers/55854.html
--Syed
I don't have 2017.3 version. Also I have to use 2016.4 for development of this project.
On the other PC (both run ubuntu 16.4) the same project implemented correctly.
I'm trying implementation on "faulty" machine after vivado restart.
@gumas,
Can you check and compare the setting and environment of working machine with the faulty one?
You can try re-installing vivado and see if it helps.
--Syed
What should I compare specifically?
It seems that if I get an error and rerun implementation from the step that failed, second try will also fail.
On the other hand implementation might (one out of one tries) be success full if I rerun whole implementation.
Best wises
