LichengGuo-UCLA
Vivado "write_checkpoint" no routing results
When I tried "write_checkpoint -cell XXX" from a routed design, it seems that the routing information of the selected cell will not be dumped into the checkpoint. The checkpoint only contains the placement result.
Is there any way to dump the routing of the selected cell as well?
Thanks for your help!
hongh
Please avoid dumping the routed dcp for a cell in a non-DFX design.
