WARNING: Par:288 -IBUF has no load
Hi, My current work is targetting Virterx-4.
The Place&Route step was performed after assigning each in-output pin.
However, I got the following  messages
WARNING:Par:288 - The signal ea_in_IBUF has no load.  PAR will not attempt to route this signal.
WARNING:Par:288 - The signal wbi_dat_i<20>_IBUF has no load.  PAR will not attempt to route this signal.
WARNING:Par:288 - The signal wbi_dat_i<21>_IBUF has no load.  PAR will not attempt to route this signal.
WARNING:Par:288 - The signal wbi_dat_i<22>_IBUF has no load.  PAR will not attempt to route this signal.
I can't find the reason of this problem, and the interesting  thing is that "wbi_dat_i" is declared as 32 bits in my work.
However, this problem is occuring only on the 16~31th bits!
0~15th bits are alright.
Dose anybody know how to fix it??
Plz tell me, any clue about these kinds of the problems
Maybe the missing bits of wbi_dat_i have been removed during the synthesis. Check it in the .syr file.
