spilipchuk
Why won't Vivado automatically create needed buffer when using inout / bidirectional port?
So I was trying to use this I2C component which obviously uses inout port for clock and data and I'm having hard time making it work.
To test how inout ports work I've setup this simple project (see attached).
The issue seems to be that Vivado won't automatically generate correct buffers for the INOUT and is giving me the following error during implementation:
  • [DRC RPBF-3] IO port buffering is incomplete: Device port SCL_PORT expects both input and output buffering but the buffers are incomplete.
Think is when I was implementing this using Xilinx ISE suite there was no issues whatsoever. Everything was automatically generated.
Any help and pointers would be greatly appreciated.
hongh
Hi, @spilipchuk ,
As an inout port, SCL_PORT should be used as both input and output.(Both driver and load)
In the test design port SCL_PORT is only used as an output(loader), so the IOBUF is not inferred automatically.
Please try to use port SCL_PORT as a driver(input) in the test design.
spilipchuk
I added the following line but now I get "SCL_PORT has multiple drivers" error.
SCL <= SCL_PORT;
drjohnsmith
So its VHDL
Well,
A few house keeping things
   don't use all those libraries,
https://www.nandland.com/articles/std_logic_arith_vs_numeric_std.html
next in the test bench etc, dont use the
component TOP_MODULE
port(
EXT_CLK_IN : in std_logic; -- External FPGA clock input
SCL_PORT : inout std_logic; -- EPROM serial clock
OUTPUT_PORT : out std_logic); -- for testing purposes
end component;
just use
uut: entity work.TOP_MODULE
PORT MAP (
last in your code you have
SCL <= SCL_internal;
and
SCL <= SCL_PORT
QED, SCL is being driven twice,
@spilipchuk
The goal is to connect an IOBUF to your VHDL inout port.
It is possible to infer the IOBUF by writing your VHDL is a special way.
However, I think you will find it easiest to simply instantiate the IOBUF into your design and connect it to the inout port using VHDL.  See UG953(v2020.2) starting on page 382 for details of instantiating IOBUF for a 7-Series device.
You might find some useful I2C ideas in <this> post.
Cheers,
Mark
spilipchuk
I appreciate everyone's help. What really bothers me is why I didn't have this issue with inout ports when I was using ISE. I thought Vivado supposed to be the "new and next great" thing but it can't even automatically generate required buffers based on HDL which ISE did.
spilipchuk
Can someone post a simple example using inout port using Vivado and in VHDL without manually instantiating an IOBUF? I just can't seem to get it. The only time it works is if I make all IOBUF "I" and "O" external ports (physical pins) but that seems ridiculous since usually those signals are controlled by internal fabric. The minute I change them from ports to signals VIVADO can't automatically create the IOBUF and gives me error about incomplete buffers.
drjohnsmith
Did you read my post ?
   You have a typo in your code,
spilipchuk
Yes I saw your comment. Thank you.
I cleaned up the code and even removed the test bench as it is not needed at this point since I can't even get the design to work.
Please look at the attached cleaned up code. Vivado still refuses to instantiate the proper IO buffering and is giving me the following errors:
  • [DRC RPBF-3] IO port buffering is incomplete: Device port IO_PORT expects both input and output buffering but the buffers are incomplete.
And in the schematic it is clear that the IO_PORT buffering is wrong and there is no route from IO_PORT to the internal fabric, only out.
drjohnsmith
Nothing strange there,
  you have
IO_PORT <= OUTPUT_sig WHEN EN_sig = '1' ELSE 'Z';
INPUT_sig <= IO_PORT;
But INPUT_Sig is not used in your code,
   so the tools trim it out,
      that's why there is no bidirectional
Strongly suggest that you believe in the tools as the first stage,
    Not making the buffer is very very common, you would not be the first to use them, so others would have found the problem is mor eliekly than it s a problem,
    Not saying a problem is impossible, but ocams razor says the tools are more likely right in this case.
https://simple.wikipedia.org/wiki/Occam%27s_razor#:~:text=Occam's%20razor%20(or%20Ockham's%20razor,the%20more%20unlikely%20an%20explanation.
If your in doubt
Try this code
https://startingelectronics.org/software/VHDL-CPLD-course/tut16-tri-state-buffer/
It makes a nice tri state buffer, that also works in the test bench
You will get there
You will not believe ( I hope ) the stories I have about obvious mistakes I made , and still make,
   ( like the coin that got stuck to back of a board on bench, and made intermittent short, took hours till I lifted up the board and coin dropped out , I could have sworn it was a ghost in the board )
spilipchuk
Haha we've all been there. And its usually something small and seemingly insignificant that breaks the whole thing.
So I don't know why Vivado considers INPUT_sig not used. Do all signals HAVE to go out to external port in order to be considered "used"?? What if I just want to run a process run infinitely without outputting anything outside of the FPGA just for the purpose of using the FPGA as heat generator to warm up my garage? How do I do that?
But anyway, I've change a code a bit to put the INPUT_sig to use. See attached. Now Vivado is telling me the design is empty and implementation fails.
drjohnsmith
The definition of a used signal is one that ends some where
   Normaly thats an IO pin.
The tools are very good at trimming back signals that are redundant,
One big thing,
  You are missing the Simulation stage now,
      Simulation is where al these problems can be identified and fixed,
    they are just like your C compiler, in the bit run on the CPU, all the redundant bits are optimised away.
In FPGA land we do not compile and hope, there is just to much going on inside the chips that we code to have few ideas as to what's gone wrong at run time.
So even if you have a great big function , that ends up at a single output , for instance a monitor circuit driving a led,
   if you forget to connect the led, all the monitor circuit will be removed as its redundant.
drjohnsmith
quick look at your code,
You have faults here
process (EXT_CLK_IN_PORT, OUTPUT_sig, counter) begin
and
process (EXT_CLK_IN_PORT, INPUT_sig, EN_sig) begin
Both of these the tolls would have warned you about.
Go back to the simple example I sent you the link for,
   make certain you can run that and a test bench,
    You are making all the classic beginners mistakes, we have all done,
        you need to learn now how to debug them, as later it will get real complex, but the same skills will work on complex debugging.
In the simulator, trace your faulty signal back, trust the tools, and check the warnings the tools give you
spilipchuk
Okay I narrowed it down to the fact that Vivado doesn't like something about this kind of statement: IO_PORT <= OUTPUT_sig when EN_sig = '0' else 'Z'. It doesn't seem to have anything to do with the type of signals in this statement but the statement structure/type in itself. Actually Vivado would give me an error that this is not supported when "Type" setting for the source file was set to VHDL  and not even run synthesis - I had to switch the type to VHDL-2008! But even then I was having all kinds of issues as discussed in this tread above UNTILL I changed that statement to the following:
process (EXT_CLK_IN_PORT, EN_sig, INPUT_sig, IO_PORT) begin
     if rising_edge (EXT_CLK_IN_PORT) then
          if (EN_sig = '0') then
                IO_PORT <= INPUT_sig;
         else
               IO_PORT <= 'Z';
        end if;
    end if;
end process;
This finally results in what looks like correct IOBUF inference. The T ling is tied to ground for some reason but I think that's because its not really driven by anything in my code.
drjohnsmith
Your original code had faults,
   which is why it did not work
This new code of yours is better ,
     its has no faults, but has warnings,
look here
spilipchuk
Whats wrong with that line?
By the way, any idea why the second process is completely ignored? Is it again because those signals don't go out to a physical port?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity TOP_MODULE is
port (
EXT_CLK_IN_PORT : in std_logic; -- External FPGA clock input
IO_PORT : inout std_logic); -- Bi-directional IO port
end TOP_MODULE;
architecture RTL of TOP_MODULE is
signal EN_sig : std_logic := '0'; -- tri-state direction control signal for the IO port
signal INPUT_sig : std_logic := '0'; -- signal from the IO port to the FPGA internal fabric
begin
-- if EN signal is 0 IO PORT is an output, otherwise in high-Z mode or input
else
IO_PORT <= 'Z';
end if;
INPUT_sig <= IO_PORT; -- creates a route from IO PORT to input signal for when IO PORT is an input
end if;
end process;
if (INPUT_sig = '1') then
EN_sig <= '0';
end if;
end if;
end process;
end architecture RTL;
drjohnsmith
a) look at the sensetivity list, and what is sensetive in the process
b) strongly suggest you get this book
http://freerangefactory.org/
c) Your second process, You have to understand the tools, in synthesis the tools are trying to fit your code, like in C compilers, any unused signals are removed. As you say , the second process has no need to be there, so its removed.
